Steve Plucker
Does anyone have any 1929 Model A or AA frames for which I could get some information off of?
Here is what I need...
I am upgrading the article I did about the Starting Crank Bearing but this time I need some information on the holes (round and oblong) on the 1929 Front Cross Member for which the Starting Crank Bearing sits in.
What I need, if you can get a few minutes to look, are the placement of the two holes on either side of the square hole for the top of the spring bolt.
Could you stand in front of the cross member and note what side of the square hole is the round hole and the oblong hole.
In other words is the round hole on the right or left side of the square hole, and/or is the oblong hole on the right or left side of the square hole.
All 1928 Front Cross Members had round holes but the 1929 Front Cross Members had both, round and oblong.
Thank you.
Steve Plucker
Thank you.
Steve Plucker
