Sounds now like the timing is retarded.
Lever full up, very slow 'Model A' idle
Mid way, idle speed picks up and idle should be good
Full down, engine speed should start to roll
Also sounds like carburetor may need cleaning again. Make sure passage ways are clean. Do not remove/drill out plugs. Use Deep Creep spray, torch tip cleaners/paper clip, compressed air.
