Bob from Northport
My shop just got a 1926 coupe in from a customer. Has been sitting for 30+ years. Engine rolls over, and we had one attempt by the engine to kick over, but no.
1. Is there a way to check the coil box out put with out an expensive tester??
2. The battery cables are badly corroded, the floor starter switch gets very warm when used a lot. Will new cables and clean connections make this starter roll a bit faster??
3. What is a compression range for the cylinders??
4. Can you give us a direction on where to begin checking the non start issue?
Thanks!!
Bob
Thanks!!
Bob
