in my opinion you will be much better off using the chevy 3 wire alt, more dependable and no issuses like you will find on the one wire, one wire alts the motor may need to be wound up to 1800 rpm to excite them, and they have been known to not disconnect electrically and run the batt down over nite
.......the one main advantage of the three wire alternator as I see it is that you have to run an ignition light with it as part of its system.
This will tell you straight away if you are on the move and you have a fan belt or pulley failure.
The ignition light will let you know something is wrong before you cook the engine.
