trainguy Well-known member Sep 22, 2010 #1 How do you remove the lock mech from the handle's?I found new matching tumblers and want to replace the old ones. Thanks Phil
TerryOH Well-known member Sep 22, 2010 #2 insert key and turn about 1/4 of the way, insert a paper clip through the small hole in the handle and press down to retract the retaining pin, then pull the old lock cyl straight out using the key. try this procedure with the new cylinders first.
