fast fredy
Hi guys , my first question here . I have a 55 Country Sedan with 272 OD have just changed head gaskets and want to pull the oil pan to remove crud and change gasket. The manual says take out the pan bolts , be sure #1 is on TDC remove oil line and remove the pan. Did that but there is only 3/8 inch clearance between the crossmember and pan.. I see there is a large multishaped bracket on the very front of the engine ,with 2 spring mounted bolts . Does this have to be loosened/moved or engine and or ****** raised somehow? Would be a lot easier on a hoist obviously , not so much on the floor
This is my first Ford , used to be a chevy guy , these fords a quite a different animal than a sbc, but I'm learning a lot and anticipate a great wagon .. Any help or suggestions would be greatly appreciated . thanks Fred
