Zephyr Progress
Ken/Alabama
Finally got back to work on my Zephyr . Got the front end welded back on and the hood fitting like it should.
Nice work, Ken.
One thing springs to mind, though, I think I'm right in saying that the frame should be supported where it would normally be supported when fitting body panels, in other words, at the crossmembers where the springs attach. Using the rotisserie might (only might) cause the frame to droop slightly which would un-droop when supported correctly.
It may well be fine, but if you find things change when it is up on it's axles and full of seats etc, that may be why.
Mart.
Ken ,looking real good! Great to meet you at Moonshiners too! I checked my stash for your 40 ashtray, sorry but I only have the side panel one. Keep the pix coming!!! RPM
Well, GOOD to see you are not working your fanny off at the plant and getting some real work done on the Z-car. Missed you at Moultrie, and will look forward to Feb. Stan had some bad luck with a beautiful Harley neon, but I will let him tell you about that. Regards from East Al. jiml...
