Mike kitto
Is there an advantage to using them in a 1939 coupe?
... a light roadster with a "hot" engine ...
That's you, Tim. Unfortunately. it's different with a full bodied street car.
Zephyr gears were designed to be used with some sort of overdrive and require a low rear end ratio (4:11 and 4.44 were common) to be practical. You have to remember that all Ford transmissions are 1:1 in high gear. Running these ratios on the highway without the benefit of an overdrive requires the engine to run at higher speeds than normal to maintain the desired cruising speed. If you have a light car and and engine that is modified to run at these higher revolutions, you can pull off using Zephyr gears for all around driving. Otherwise, just getting the car moving off the line and cruising at normal highway speeds is uncomfortable.
In the current situation, we do not know enough about the O/P's vehicle to give a good answer. What is the current rear-end ratio? Does it have any sort of overdrive setup (maybe a Mitchell or a Columbia) now? What modifications (if any) have been made to the engine? If the O/P has just an "ordinary" car and expects the installation of Zephyr gears to be some magic performance enhancement, the answer is most likely "NO". Top speed will be the same and driveability will suffer.
I fully agree, I usually receommend 28T for most transmissions I build, sometimes we use the 29T with high speed rear axles for good starts, very few use the Zephys except in light weight cars and "bragging rights". All info is just my opinion on here. Paul J.
The reason them darn kids wanted them was for inner city drag racing in one block increments. You could wind up 1st gear high enough to not lose time shifting and beat the other guy to the next light. No reason for normal driving.
