JOES31
I had an old Zenith carburetor that I thought I would send in as a core and get a "professionally" rebuilt carb. I sent it and received a rebuilt Zenith. I put it on and as soon as I turned on the fuel it leaked like a river. It was coming out of the atmospheric vent. So I assumed the float was set too high. The sheet that came with it said warranty void if the unit is opened.
So I sent it back for another.
I received another one but on this one the threads for the fuel inlet were half worn down to nothing so the compression fitting would not seal. So I sent it back.
I just got a replacement and this time it leaked like mad. The bolt in the bottom that tightens the two halves is too long and will not seal the two halves. The lock washer isn't collapsed and the bolt is tight.
I am really tired of dealing with this. After three times should I just ask for a refund and tell them to keep the core or just forget it and move on? What would the rest of you do?
