mach0415
Hello. As we were mounting the freshly rebuilt Zenith 1 to the intake, it was noted that the upper body flange to intake mounting holes have been drilled out. Chalk it up to the fact that this was overlooked upon my rebuilding it.
So, the questions:
1.) Do we simply mount it with nuts and bolts (originally mounted with bolts that threaded into the carb body)? Its to be a driver. We'll worry about judging standards at some point on that.
2.) Do we weld them shut, drill and retap?
3.) Do we not waste our time and just get another good, used upper body?
4.) Is this a common issue found over the years as people have over/under torqued and stripped out?
Input is appreciated
Mark in NC
So, the questions:
Mark in NC
