Zenith carb
Dkrahn
I have the threads in the bottom of zenith carburetor stripped. Not the one that goes all the way through to bolt together, the other one. What is the answer to get that to seal up? It is not a standard bolt as it has a hole in it. Is there a value in that hole? Can I use a longer bolt, without the hole??
Might be difficult to fix bad threads in the casting. I have unmatched bottom castings, and the parts houses were selling replacements.
If casting threads are very bad then Tom Endy's is the best solution ( other than a new casting!). Often the threads on the brass drain are very worn yet the casting threads not too bad in which case a new brass drain will solve the problem. Sometimes if casting threads are worn grinding the casting down a little will get a new brass drain onto decent threads to get grip.
Can u send me a link to someone who sells replacement bottom casts?
Whats your location? Ill send you one! I have many extras ! The picture is all rebuilt float tested. As Tom Stated easy to fix with old screen plug!
I have looked at Tom Endy solution and I went looking for that filter screen and cant find it.. I have seen them on cars, but cant see where to order.
Thank you much. I also updated my profile, to contact me. Don't you need to get rid of any of those Zenith 1 carbs?
