With the secondary well installed and tightened in position, remove the Compensator Jet and using a sharp nail or awl, scratch the side of the secondary well. Then remove the Secondary Well and using a dremel tool, grind a groove around the Secondary Well from the scratch mark to the fill hole. Dont't cut too deep, just enough to increase the gasoline flow rate to the fill hole. I hope this is helpful, Ed
