ScottNW/Ohio
I've probably seen this info somewhere, but I can't find it now -
I'm getting ready to reassemble a Zenith (2?) carb for my pickup
How do I check the venturi to see if I need to replace it ?
I'm rebuilding it because it was low on power and seems to make the engine run hot
(I swapped it out with a Tilly, and it ran much better)
I'd leave the Tilly on it, but I'm determined to try to make this Zenith work.
I've throughly cleaned the carb body, and got a new kit and float from Snyder's - but wondering if the venturi is part of my problems
