Ed in Maine
Recently I have had some problems with my float valve leaking and sticking closed. I would like to know what type of float valve has given you the best service? Where are you purchasing them? Thank you, Ed
the modern fuel will make a viton needle stick shut if the vehicle sits long enough with the bowl full. I have seen this repeatedly with golf cars stored over the winter. Golf cars aren't model a's but the needle valves don't know that. A solution for them was having a wire clip that loosely connected the needle to the float, when the bowl empties the weight of the float will pull the needle open. Most all "modern" carbs do this.
