Zenith 2 upper body
David31dlxslant
Ringgold
Ga
Wanted : I need (2) zenith 2 upper bodies, I have the lower bodies and need to finish them. Thanks for any help, I need them to be free of cracks or breaks or any kind of damage that would prevent a good rebuild, I install new throttle bushings so a worn bearing where the throttle shaft is acceptable
Just to clarify in case you're not sure what you have or what I mean by zenith 2 upper bodies, zenith 2 carburetor upper bodies had no exterior markings and were made by Holley and most of them had an H on the inside where the float valve is stamped on the underside, zenith made upper body carburetors had a Z stamped on the throat below the throttle arm
