olut
Hi colleges,
My 1929 Roadster Pickup is euipped with a partially repaired engine with retrofitted adjustable valves and a modernized rear main seal with kork/neoprene, original distributor and a new zenith cab (installed by previous owner). The engine runs well, has full power, high torque, idles relative smooth and does not use any oil.
There are only two issues not to classify the engine being perfect:1) it uses relative much fuel on long range rides at average speed of 40mph (12mil/gal), and 2) it stalls when stopping.
I understand the reason for 1 ( jet size, mostly too big) and 2 (fuel level inside bowl too low to feed idle jet during this moment)
My problem is, the garage where my Ford is parked (center of Vienna) does not allow repairs and eventual towing out is impossible and my mechanic is as buzy as I am.
My intension now is, to purchase a new zenith, which will be perfectly adjusted on a perfect running engine and then send to me. Does someone know a dealer/mechanic who provides such service.
It's not urgent, the vehicle works well, but not 100% perfect like I expect it.
Thanks for feedback
Cheers from Vienna
Albert
Thanks for feedback
Cheers from Vienna
Albert
