Any recommendations on this anti-wear oil additive?
can it be used in regular model a engine?
It not only prevents cam scuffing, it reduces ring wear.
Reduced ring wear equates to longer engine life.
Now I suppose you guys with your "low spring pressure" model A's
are going to tell me you have low pressure rings also.
So how is ring wear and scuffing prevented in modern engines with the new low zinc oil?
Actually, NO. . . .
By "NO" do you mean Model A rings are not low tension? That is what my "yes" referred to in your original question. Good luck getting those fat, 1/8 wide low tension stock A puppies to seat in 1/2 mile. They float on the oil like water skis. I don't care if you bore with a torque plate and do the latest fancy double plateau hone. After 1/2 mile you will not have the compression you will at 1000 miles. That's why I like modern rings, especially sets with a moly top ring. Those seat in a few miles. Stock A rings will never muster enough pressure to break down the film strength of oil. They will only scuff if oil starved, overheated, or run much faster than a stock A will run. I'm not against ZDDP, but it is not like the A was designed in a way that needed it and we have now been denied.
Notice in my original post, I did not say a model A NEEDED ZDDP...I said it would prolong the life of the engine...You can run it on liquid margarine for all I care.
And Mike, you are full of it if you think one of my engines won't make more hp on the dyno after 1/2 mile break-in than it will at 1000 miles..Any engine built right will never run as good as when brand new.
One more thing, apparently you do not understand what seats rings...It is not the tension built into the ring itself.
Pete, My apologies! I didn't know the discussion changed to race engines. I'm sure one of your builds will make more HP after 1/2 mile than at 1000 miles. Most race engines are ready for fresh rings at that point. I built my share of SBC's for dirt circles in the '70's. The focus here is pretty much stock A's. Most stock engines are just about broken in at 1K miles. Yes, you did not say a model A needed ZDDP, you did say it would prolong the life of the engine. I'm not contesting that. In fact, I agree. Overall wear may be less. What it won't do is ward off some early specific part failure because the "A" build design has no components with a critical need for extreme lube film strength.
