Any one use this stuff in your model a engine?
Is it important to use in a babbetted motor on break in?
Why no zddp? I won't let ANY engine leave my shop without it.
Dudley
That's correct Mr Tube. ZDDP was designed for the higher spring pressures and flat tappets beginning in the 50;s. Today's engines normally have roller tappets or overhead cams and don't require it. Kind of leaves the motors it was designed for out in the cold. I lost 2 cams in 2 different small block chevys because of this. With the low spring rates of the Model A it is unnecessary. It won't hurt to use it, it's just an added expense for no good reason.It is my understanding no oil had zddp in it when the "A" was designed and the low spring pressure of the "A" does not require it.
Thanks James and Hard times. I'm glad I asked first. I was told to use it by a friend who said he heard that from someone else and to check into it first.
Rotella 15w 40, thats what I use in my diesel truck. I get it from Tractor supply.
Same stuff?
Or $4.00 gas...after all the thousands put into building an engine to run like a 'singer', to fret over cost of four qts of oil!
I like your attitude!As was stated, in response to your original question...i.e.- if concerned(that your oil doesn't contain the additive) then use Rotella...which does contain it! Which is why truckers use it , I am told.
I don't give a hoot about this additive, in model A engines, but use Rotella: because of its various other good qualities! And, I figure, truckers use it because it preserves their diesel engines (which may be worked slightly harder than my B)...cost be damned...after all the thousands put into building an engine to run like a 'singer', to fret over cost of four qts of oil!
I was told to use it in our new rebuilt engine...the builder has been around for many years and has rebuilt a lot of model a engines!
