Google "ZDDP yellow metals"
Here is one:
https://www.machinerylubrication.com/Read/30048/zinc-hydraulic-oils
Hi all
Sorry if it is a naive question , but I couldn't find an answer online.
Anyone knows if ZDDP additive will react with or affect yellow metals ?
Thanks !!
Daniel - Forddan-
It can, but zinc not necessary in trannies, rear ends and steering gears, etc. Rotella and other motor oils used to be higher in zinc, but it was found to affect catalytic convertors. Some people add the ZDDP to motor oil (not hydraulic oil) in classic cars for the valve train.
Hi all
Thanks !!
Daniel - Forddan-
Duke36, ZDDP will not be a problem to the transmission gears ?
If I use a mixture of 600W oil and STP, the ZDDP will not be a problem ? Also for any yellow metal I could have there ? Mine is a January 29 Tudor and I do not have idea how much is still original in the transmission.
How many more times are you going to ask the same question? This is your second thread on the same issue in as many days and numerous people have answered it and provided links for further reading. People have told you what trans oils you can buy that are thicker than 600w as well as being yellow metal safe and where to buy them. What don't you still understand?
Thank you !!! I missed this one or I misread it. Nevertheless on thst link is the answer to my question !!!
Thank you to all and have a great long weekend.
Daniel
My question was to Ducke36 and he answered it. Thank you Duck36 !!!
Cheers
Daniel
