NSDWS
Man I hate electrical problems. (39 two door standard sedan 6volt) I have tail running lights on right and left, problem is when I step on brake peddle my right tail goes out and brake light does not come on. Left side is all good. This could get long so hang in there. So I looked up under car and saw one wire coming from the housing looping up to a mounting screw and one going to the crossover harness. So I took wire that was on screw and hooked it to the other wire that was in crossover harness. That gave me both tail lights working and both brake lights working but when tail lights are turned on when step on peddle the tail light still goes out, but with tail lights off the brake light will work. See what I mean I hate electrical problems. Ok so now I take the right housing out of car and get good look and see that the housing was pretty much rusted out at one point and someone had put a big glob of bondo in side of it and stuck a bulb socket down in it. My thinking now is that my ground is bad or I have no ground on that side, but if that was the case would the lights not work a all. Prior to the work I did I did not have brake or tail. Am I going in the right direction with this or should I be looking elsewhere? Hope I explained well enough to understand.Thanks Doug
