When you say 'adjusting the yoke nut', do you mean torqueing it down tight?
I took a 18" length of 3/16" thick steel, approx. 1 1/2" wide, drilled two holes along one edge (to bolt to two holes in the flange) and ground a notch along the edge between the two holes so a socket would fit on the yoke nut.
I can take a photo if it will help.
...Terry
