lucky_stripe_garage
One of my thoughts too. How well lubricated is it and with what?
Other than that, it seems something is moving. I suggest checking everything from timing lever to points. Maybe the pin holding the little lever on the bottom end of the timing lever is broken allowing the rod to move in the small lever. Is the distributor itself moving in the head? Take the rotor button off and try moving the cam with your fingers. In short, assume nothing.
What should it be lubricated with?
