37slantback
*EDIT*
I got it. The steering column was in back of pickup so I dropped the steering wheel into the end gate valley and pulled the horn rod out.
I have the steering column out of my 37 and I am taking it apart. The horn rod will move about 2 feet and then hangs up. I had to do some gentle twists to get it that far. Is there a trick to removing these? It seems in most threads I found that once the bottom clip is removed it should just pull out.
Thanks,
Don
Thanks,
Don
