fordor41
I have a '60 292 Y-block with a 2 speed fordomatic that grenaded itself 3 days ago. I'm wondering if a 3 speed cruisomatic would work as a replacement. My ford shop manual lists 2 speed fordomatics as used with 292 y-blocks and 352.
Fluid pressure settings are different between the 2 engines but no other info as far as interchangeability. so if cruisomatics 3 speeds were used on 352's, would they work on a 292 y-block? also y-blocks were used in trucks until about 63-64 depending on where you look. I assume the 2 speed fordomatic was gone by then. or is the bellhousing bolt pattern that makes the fordomatic/cruisomatic not compatable between the 2 engines?
