Y block overflow tubes
Ole Don
Some have questioned my overflow tube change. Below are pictures of before and after. The after pictures show hard chrome shafts sold by John Mummert, I bought these in 1999 and assembled low mile unworn 1.54 rockers. The first pictures shows rockers that came off an old well worn Y block.
The second picture shows well worn shafts, with much more wear on the left end.
The third picture shows the shafts on the engine I just sold. Run hard and raced several times since 1999, there is a witness mark, but no wear on the shafts, just a nice film of oil.
Picture four is another part of the same shaft.
Picture five is the stand where the oil goes up. Another story will tell why there was way to much oil up top. The hole in the stand is the right size to tap 1/4- 20 and put in a plug with a 1/8 orfice.
Picture six is the trick I have been talking about. Cut the overflow tube to get a square end, and debur the inside. The ID is the right size to tap 12-24. If you buy a screw with a phillips head, the screw will guide the 1/16 drill bit, drill the length of the screw and debur. One drop of Locktight on the threads, screw it in, and blow through it right away to be sure Locktight didnt plug the hole. Do a trial fit to make sure the OD of the screw head isnt too close to the pushrod, some grinding may be required. After this change, at hot idle, you should see as much oil out the left rockers as on the right. These rockers and shafts should now last my lifetime and one more guy after I am gone. Total cost for this change is about a half a buck.
Good stuff, Don. Another alternative if you don't want to fully pressurize the rockers, altho I suspect Don's rocker setup does have some pressure.
Good to see you "learned" how to post pictures. And thanks for sharing with us.
Yes Gerry, the shafts are the same on both sides. Whichever side you are facing, the rockers and shafts get much less oil on your left.
Nice right up Don. Even a "Boy" should be able to follow it. I did something less involved but still effective at increasing the rocker assembly oil supply. Put the overflow tube in the corner of a vice, with maybe 1/3 of the tube diameter outside the jaws. Tightened the vice and flattened the 2/3 part of tube.
What happened Don? Did you get a bit heavy handed relieving behind the centre cam bearing?
Regards
