Jim.UT
55 Ford Fairlane with 272 Y-block. I've had the car a little over a year. On the first oil change I noticed the drain plug didn't have a gasket, so I made one out of a carboard cereal box. The car drips oil...enough to make the wife complain. I looked under it today and tightened the drain plug a little more. Don't want to strip it so I'm careful. While laying under the car I can see oil slowly seeping past the drain plug.
Question: should the plug have a gasket or did I create this problem by adding a homemade one?
Oil may be leaking from other sources (oil pan gasket, valve cover gaskets, etc) but I don't have a major oil loss other than the slow drips. I know other leak sources may be running down and dripping off the low point (pan drain plug) thus masking their true source, but I'm pretty confident that the drain plug itself is leaking based on my observations during my morning nap under the car.
Thanks for any insights.
