you dont need any sealant orther than just a little on the manifold itself to help hold the gasket in place till he gets the manifold down on the engine, if he really thinks he needs more put it on the manifold only, that way if he has to remove it later the gasket will be stuck to the manifold , makes it a lot easier to remove and nothing falls into the valve galley
