46international
I found a set of ECZ-G heads for my Y block and plan on installing them in a few days. The question is, when I built the motor last year the directions that came with the head gaskets said to drill holes in the block that line up with the 1/4" or so holes in the gasket. these holes are above and below center line between the center two cylinders. The heads that are on the motor now had the holes in them just the block did not.
The new heads do not have these holes, should I drill them?
