Y Block Chrome Pulleys etc are they made?
ken1939
I am trying to find chrome pulleys for my 292. I do not see that they are available, and I know I could get mine chromed. However, are the hole sizes similar to the Small Block Fords in any way. I cannot seem to remember.
I know they make a ton for the SBF, and if they would work that would be good.
I am dealing mainly with the lower crank pulley, and it can be a one belt, and one for the fan. The engine is going into a 32 Ford so I am not concerned about other accessories, and I can relocate the alternator.
The Y block water pump pulley has the same center hole and bolt pattern as nearly all Ford V8 engines built up to the mid 9's. Check the set back, there may be one you can use. The lower is cast, part of the damper.
