smtichy
I have a '55 Sunliner, with a 292 (casting no. shows it as a '59)
This weekend I did a tune-up and hit a bump when checking the timing. The timing pointer on my car is different than that shown in the shop manuals. [See thumbnails attached at bottom, double click to enlarge].
The timing pointer has 4 points marked clockwise 10, 6, 3, 0.
Anyone familiar with this type of pointer on the Y-block?
If so, which point matches the standard pointer and should be used to set timing?
The damper is stamped TDC followed by 6 marks. The timing light shows the point on the pointer labled "10" between the 4th and 5th marks on the damper.
FYI in doing the tune up, I checked points, plugs, idle, dwell, vacuum, etc. None were within proper specs
but now they are sorted.
I've had this car for about 6 months now and have been getting it into good shape thanks to all the knowledge you all have shared with me.
Have a great weekend!
p.s. - a picture of a similar pointer below:
