46yblock
I have a late model B 4V intake with the choke heat riser that runs through the crossover. The tube is good, not burned out. Having never used this setup for an automatic choke, what is the ID/OD of the tube that runs between the choke and the outlet of the crossover riser? Does the choke tube insert directly into the hole in the center manifold leg, or go over a nipple outlet at the center leg?
Currently there is a very short nipple at the manifold outlet, 1/8-1/4 in. long. I am wondering if it is a piece of broken choke tube that needs to be drilled out or otherwise removed.
