Wtd Transmission coupling shaft
WTD. late 31 AA coupling shaft for back of 4 speed transmission for 131" wheel base, looking for the late shaft with U joints both ends, also would need the torque tube for the coupling shaft, and the rear trans bearing retainer casting that bolts the torque tube of the coupling shaft, to the back of the transmission. The 1932 BB truck is not the same. Thanks for any help,Ed
BTT- Still looking although Ford built a lot of big trucks in 1931, most got their cabs & sheet metal removed from restorers, & hot rodders to build pickups. I am looking for a coupling shaft off a 1 1/2 ton, 131 ' wheel base, late 31 with u joints on both ends of this shaft. Need the complete shaft with u joints, u joint covers, and shaft cover, or shaft { torque tube }. Thanks Ed
