WTB master cylinder 1951 MERC
tony lucckino
prescott,
az
Need a master cylinder for my 51 merc. New or used ,with a good bore. 1" bore. email or call Tony 928 776 2445. thank you
tony now is the time to install mustang dual bowl master from non power brake 65/67 mustang with special adaptor bracket from fatman fabrication in charlotte.the bracket is about $80 and the master cyl is about $50.a little plumbing ,you will attain front and rear brakes independently..worked great on my 51 merc..if your front brakes ever fail you will at least have rear brakes with that set up!
