WTB: 30-31 Model A Coupe Subframe or rails
mike47
New member
anywhere
anywhere
I'm new to the Ford Barn but you can check me out on the Jalopy Journal. Been a member over there for years.
It's time to get my coupe body assembly started. I'd like to use real Henry Ford steel as all my other parts are original. I need both sides sub rails but if you have one I just might take it. Just need the rails but might take any other pieces or a complete assembly as well. I don't mind doing a little patching or if they are a bit pitted. Not expecting too many miracles here. The closer to central NJ the better but I'll pay to ship if they are good pieces. I could even use from the mid door area back if the cowl was cut off as I have decent front parts.
Cash, trades, I can even swap some labor if you need any machining, welding or other fab work done. Check out 47fab.com for some of my work. Contact me via email or at 908-526-8865. Thanks,...Mike.
