WTB 1942-52 Pickup 3-sp Speedo Gear
Barn Junk
Tri-Cities
WA
Previous owner was a little abusive in removing/installing the tailshaft mounted gear so I could use a better one. The number stamped on the backside face is " 21-C-85-C8 ". This is a light duty, 3-speed, open drive transmission. Let me know if you have an extra one.
The 3 spd LD transmission was changed to a side shift in 51. Not sure if the gears would be the same as the result. Just wanted to point out the change in design.
