Wrong dipstick
aermotor
I changed my pan gaskets and put 4 qts. of oil in through the distributor shaft hole. When I pulled the stick only a drop was showing on the end. About what should the level indicate on the stick with 4 qts? The engine hasn't been started yet.
John
If the dip stick you are using indicated correctly in the past, then there is nothing wrong with it. However, if you changed dip sticks, then I would be suspicious of the replacement one.
There is no harm putting 4 or more quarts of oil into the distributor hole. The oil will overflow the dams in the valve chamber. Some of the oil will go down into the oil return pipe and some of it spill out into the timing gear case. All of the oil will eventually fill the connecting rod troughs and the crankcase, but it will take more time to do so.
When I just changed my oil, I put about 4 qts in and a drop showed on the stick. Added about 1/2 qt and the level showed to the full line. About because I was filling with a 5 qt container!
Model a holds 1 imperial gallon (1.2 us gallons). the 0.2gallon remains in the valve chamber and dipper tray on oil change.
I assume both parts of the handle entered the hole, so it was all the way down.
John
The Model A Instruction book (owners manual) shows the engine oil pan capacity as being 5 quarts.
If you start with a dry sump and dry dipper tray it will need 5 quarts.
When changing the oil with a dry sump and a full dipper tray, it will need only 4 quarts.
This was a recent extensive topic either here or on VFF, can't remember which. Nor can I remember the measurements.
Ford facts booklet 1929 for use by sales, 1 imperial gallon.
4.8 quarts, 5 quarts what's the odds. point is 4 quarts isn't enough...
When I added the oil to the distributor opening I figured if 1 quart was good enough to fill the dripper tray 4 would be better, after a while the level did come up on the stick to the approx. point of 1 qt. low.
John
John
Then I guess its all good.
Here is what I found on my car. You can see the full mark difference.
NOW, we're all VERSED, on the fine ART uf fillin' our oil--LOL. If you don't poke the stick in RIGHT, you'll be AMAZED at how MUCH it dribbles, NOTHING excites us more than a "NEW" leak +*$^*&%&^%$#@
Bill Fullofit
