Ken/Alabama
Ok , I have the Sunnen machine and the correct mandrels to resize the big end and the small end of the connecting rods. What I don’t have is the know how to remove the bushing from the small end of the rod.
I press them out with a mandrel I made and a support plate with a proper hole to accept the bushing. The mandrel has a length at .750 diameter sufficient to extend through the rod and the clearance hole of the support plate plus about one inch. Below the clearance hole, where the removed bushing will reside, is a bore of.750 in that support which the end of the mandrel fits to align everything nicely. The clearance bore should be made only slightly larger in diameter than the bushing OD.
