would i be better off modifying this part
Topher5150
On my 47 Ford coupe (which has a Merc frame) I took off the steering box mounting plate to move it back, and the frame at that point is taller then the plate by about 5/8". Is finding the Ford steering box plate a common enough of a part or would modifying be a better bet.
Probably quicker to modify what you have if it will work properly. Or, make a paper pattern and have one water jet cut.
thought the Merc frame was longer from the firewall on, so the front axle is going to be further away as well How about the sheet metal Hood fenders,??????
that's why i'm moving everything back. as far as the sheet metal everything fits in place
I think the frames are the same just different position for the steering box mount and cross member???
The MAIN frame rails are different. The two rails are 4" longer on the Merc frame than the Ford rails, as can be seen in the drawings below. The picture below of a Merc frame and front axle explains a lot. Check out all of the special Merc brackets, like to relocate the wishbone ball, and to move the engine mounts rearward. Click on this link for a full thread that I did a lot of leg work in for Topher 5150. Note posts #4, 9 and 17. DD
https://www.fordbarn.com/forum/showthread.php?t=225111&highlight=mercury+frame
321836
321835
