D DavesAuto Junior Member Jun 28, 2017 #1 Hello guys On a seven tooth steering box will the worm gear come out the bottom of the box ? I am trying to avoid pulling the whole column out .
D DavesAuto Junior Member Jun 28, 2017 #3 I see in a diagram the worm needs to go up a bit to remove a clip then it will come down. Might have to be pressed off the shaft though.
redmodelt Well-known member Jun 28, 2017 #5 The worm gear is pressed on the shaft, there would be no room for it to come out the bottom with the shaft while still in the car. I am not sure it would come out anyway without removing the side plate that holds the 7 tooth gear.
