Worford Transmission 26 or 27
26or27
Does the Warford Transmission make the Model T a daily driver, or is it still a relic. Does the Warford transmission work together with Rocky Mountain brakes, and with a Ruxtell.
I go by what Popeye said: I only know what I know, and that's all what I :)know.
It is still a relic but can be driven further & faster like a modern car if the warford is an overdrive, which most of them were. Rocky mountain brakes are pretty essential with a warford because they will work even with the warford in neutral. A ruckstell will work with a warford too but then you will have 2 shift levers and a bewildering range of gears to choose from.
