Hi, Bob drake has all of those parts in reproduction now; swing arms $65 a pair, lift gate swing arm bracket assemblies $82 (the part that goes on the window frame), and the bracket assembly that has the chrome knob to lock the rear lift gate window in the open position $80 (P. 541 catalog 27). I have these parts as well, they are original but you should know if you want the bracket with the chrome knob that mounts on the rear corner pillar there are two types. The more common one is 2 inches long from the mounting base with the three screw holes to the end of the threads where the knob mounts. The other type is 2 and 5/8 inches long (measuring the same way) and has a sort of double bend in the cast shaft. You can e-mail me at jen.toby@yahoo.com if I can help. Thanks, Toby Lampert
