jglad Junior Member Apr 19, 2023 #1 On the cars that used wooden subrails, did the wood rest directly on the side splash shields or was there some sort of pad in between.
jglad Junior Member Apr 19, 2023 #3 So they used the same rubber pads that the cars with metal subrails and body blocks used?
Oldbluoval Well-known member Apr 19, 2023 #4 Yes, for the most part, but I’ve run across some that are bigger. (Not necessarily thickness) that the ones on steel sill cars
J JayJay Well-known member Apr 19, 2023 #5 I took my unrestored '30 Town Sedan boddy off the frame last summer. Yes, rubber pads, around 1/2" thick (although mine were unevenly compressed after 90+ years...), directly under the wooden subrails. JayJay
Bob Bidonde Well-known member Apr 21, 2023 #7 When mounted, there should be 1/4" clearance between the running board aprons and the bottom of the body. This clearance is provided by rubber pads.
