wood hardware
Hello, many of the vendors carry the wood body framing , I usually go to Snyders in Ohio-as they are close to me to pick up and seem to carry decent quality products. There is also some vendors do only wood work. May advertise on Ford Barn. Hopefully you will get more responses. Be advised that so of the best quality wood may require fitting. Good luck.
Does anyone know where I can buy hardware for a '29 coupe top wood and body wood? TIA
Are you wanting to know where we purchase the Hardware, -or are you wanting to purchase a Hardware Kit? I purchase from the bolt manufacturers since I want countersunk slotted wood screws and carriage bolts. You likely can but a box of random #10, #12 wood screws and carriage bolts online from places like Bolt Depot or similar online much cheaper than you can get them from the big box stores.
Hello again, Url: thirdgenauto.com carry some hardware for Model A Fords , hard to find body bolts and fender hardware , should you need any of that later . As far as screws and nuts for the actual top you may have to match up with what you have or perhaps another Ford Barner may have a list from a previous restoration.
