Wood graining kits
Gary
Anyone know of wood graining kits or a patch kit, I really don not want to remove the dash from my 34.
Anyone had success with a patch kit ?
Thanks for taking the time to read the post.
There is a new method of wood graining. It consists of a tank of water and some sort of decal that floats on the water. I saw a Packard dash that was done the other day and it was the best dash I have seen. It don't look like a decal, it looks better than any wood graining job I have ever seen. $250.00 for the dash, glove box door, windshield and doors. I think it's called hydrograin?? G.M.
Thanks Ted, I will get a picture, I had masking tape all along the top and when I pulled the tape several big areas pulled off the metal. Pretty ugly.
What did you use ? Home Depot has a wood graining kit.
Gary
There is also the vinyl film system they use for all the modern signage.. If there are not a lot of curves it could be applied in the car, but you would want to do the whole dash, not patch
Thanks to all , itsa52 looks like that may be a winner
Thanks Barners one and all
I checked out that transfer system of woodgraining: go to cobraimaging.com, and you can see samples of the process done on utube. As an traditional woodgrainer, I am definitely going to try this alternate method next time... Pretty cool.
If you just pulled of the top layer (clear coat )then you may be able to re coat it with clear then rub back between each 4 coats ..If it worse than that then a full job is required ,The small part that I did I took some color lacquer to the job then eye matched some to the base of the back ground color ,then I used some timber wipe on stain (the paste type ) or you can use printers ink and something with a texture in it like Burlap or a bit of foam rubber to grain it ,then clear coat it . The sytiom that GM talks about is a membrane thats floats on water they spray a activator on it ,then they dip the object in it .it .I have seen a steering wheel done and it does a outstanding job Ted
Gary
I have had my '39 std and deluxe dashboards done by the water transfer method.
The grain is not 100% authentic but the finish is immaculate.
Hi Swoop Yes its real nice .We use the Grain it technology for a full dash ,My son just did a brook ville 3 window ,Collin W ,and a 39 mercury Conv bob ferbine ,Its comes out just about as good .
The dip method is expensive ,Heres some shots of what we do
Ted,
Have you got an example of what you would use on a '39 deluxe ( medium tan base - straight grain )
Thanks,
Chris.
Swoop ,I do have the straight grain Engraved plate ,thats does Model A, maybe 30, and later v8 ,I haven used it yet, This would likly be what you want , Ted
Ted,
I have that plate from Grain-It but not the rollers etc.
I might get you to do my next one.
Got a ballpark figure for a '39 dash ?
Thanks,
Chris.
Tried that. Worked ok in the winter but on a hot summers day it tends lift at corners and the wind catches it & it goes out the window.
A coil, this one went out the window .
