RobertB
After installing the new bendix and replacing the starter, I am having a problem getting the A started.
I think I'm following the right procedure:
Emergency brake on
Transmission in neutral
Fuel lever under hood pointing out to engine (31 Slant Windshield)
Key turned on...pops out
GAV turned 1/4 turn
Throttle and advance set at 3 o'clock and 9 o'clock
Pull choke while pushing starter with foot
I had decided the problem was that I was out of fuel. When the car came off the delivery trailer, I started it with no problem and drove it into the garage. Twice I started it and backed it out and drove it around the block.
The last time I did this I parked in the driveway and ended up having to push it into the garage. Then the bendix spring broke while trying to start it. Fuel gauge does not work, so I put a stick in the tank and touched no fuel.
I assume the problem was that I had simply run out of fuel (yes I know about ***/u/me). So I just put 3-4 gallons of fresh fuel in the tank.
On the third or fourth try, it started and ran about 10 seconds. A few more tries and it ran for a bit again...I hit the gas peddle and revved it up, and then it died. No joy since then.
Advice, suggestions, sympathy?
Emergency brake on
GAV turned 1/4 turn
