larry harding
i've been tinkering with cars, motorcycles, hit and miss engines most of my 81 years. a friend wanted me to get his 29 fordor running right. it will start up and idle roughly, if you open the throttle it won't rev, just spits and coughs backfiring thru the carb, it's getting plenty of fuel battery(12v) is up. i've been
trying to diagnose this for two days. i have a coil mounted on a bracket i use to test run engines, it runs great on the test coil, i even did a little wiring to run test coil from the hot lead on the car's coil and thru the wiring, ign, switch, to the distributor. ran great! next i took a good coil from one of my cars and mounted it on the firewall same bad running. its like just being on the firewall is doing something. i've been chasing electrical problems most of my life , but this has me stumped. the fix will probably make a fool of me when i find it. ideas please!
