Scottio57
Won’t rev up
I tried to see if this was covered already but I couldn’t find it so please excuse me if it was already covered. 1930 sport coupe, all stock except B head and overdrive. Recent valve adjustment, spark plugs, point adjustment, and carb clean all to spec. In service manual. I got this car in January after my Dad passed. It has always run great but today I kind of pushed it a little. I noticed in high gear, without OD, it will run great up to about fifty mph. Light throttle, full throttle it’s all good up to fifty. After about fifty two mph it stops accelerating and if I push the throttle it stumbles and backfires. At this point I tried a little choke, thinking it was a lean condition, no change. I turned the GAV, no change. Moved the spark to full advance, no change. Full retarded stopped accelerating as it should. If I use OD it will give me about another ten mph and then does the same thing. So it seems to be RPM related, richining the fuel doesn’t help, changing the spark doesn’t help, opening the throttle makes it worse. Is fifty two all I’m going to get out of this engine. Am I floating the valves or the points ? Has anybody run into this. Any suggestions will be appreciated.
