cuzncletus
My 8ba in my 39 refused to restart after it had warmed up and been on the road for a while. I posted and got lots of suggestions. I had already rerouted the gas lines away from any heat source so vapor lock wasn't the problem. There were suggestions from timing to a low battery.
Here's what it turned out to be. I started from the coil going back to the distributor. The coil was fine, but there was no continuity in the main wire from the coil to the center post of the distributor. I replaced that and the motor fired and continues to re-fire even when hot. Evidently heat was breaking down the carbon wire. Electrons flowed when cold but a gap opened when hot. This might be a one-off occurrence but could be something for others to watch for.
No more carbon wires for me.
