Will an engine run cooler without its thermostat? Some say yes because removing the thermostat eliminates any restriction, thus increasing coolant flow through the radiator. Others say it will run hotter because of the lack of restriction. They believe that even when the thermostat is wide open, there is still some restriction, which slows the flow through the radiator thus giving the coolant more time to dissipate heat.
I have a 180 degree in there now, and am thinking about going to a 160, but maybe I should remove it entirely to get a cooler run here in the swamp that is south Texas. What do you think?
