There are bullet ends that have crimp fittings, they are available at most auto parts stores (check to be sure they work with your female connectors). They are unsightly because they have plastic coverings over where you crimp. But the ones you get from the Model A vendors must be soldered on. Strip a bit of insulation from the end, push the bare wire into the connector, then heat up the connector and feed solder through the open end of the connector. Very quick and secure.
JayJay
